Confused What To Buy?
nishant
Hello everybody,
I am new to this forum and happen to stumble upon this when i was looking at Sony MiniDisc portable players. I want to buy a player and also use it as a recorder in my music lessons. I was looking at my options and since so many models are available i was confused as to which one I should go for.
MZ-NH900 and MZ-NH1 look pretty recent and advanced models but I am confused between the differences in these two models. Please advice as to which one should i go for.
I also wanted to know if MZ-RH910 are available in US and if they are then where can i get them.
Please advice.
Thanks in advance,
Nishant
i don't know much about md, but i know some stuff. i've owned about 5 md's so far. i usually just read and don't give opinions. the mz-nh1 is the top-of-the-line md. it's thinner than the mz-nh900. the battery life of the mz-nh1 is less than the mz-nh900, since the mz-nh1 doesn't not come with a AA battery adapter like the mz-nh900, which allows it to give is more battery life after the removable battery wastes. the mz-nh1 has more options in its menu, like time-stamp, which allows it to record the day u recoded an analog or digital recording or a mic recording. i don't have either one. i don't have an hi-md basically. people have complained about many problems these new models have been having. search around this forum and u learn about them. don't mean to discourage u. about the mz-rh910, i believe it has not come to the states yet, it already came out in japan this month. i believe it's next month that they will come over here.
  • 4 weeks later...
  badnu1s said:
Do the MZ-RH910 or MZ-RH10 have or NOT have digital pitch control - the ability to change playback speed without changing pitch?
You could doublecheck with Sony, but from www.sonystyle.com it appears not since they're not mentioned. The NH1 and NH900 have digital pitch control.
