lewpei Posted April 10, 2005 Report Share Posted April 10, 2005 I recently purchased a bunch of used MD's from E-BAY a & when I tried to erase some of them to reuse the message "TR PROTECTED" came up. I was not able to ease the MD so I could use it again. What I want to know if there is any way I can erase these MD's for reuse or are they junk only fit for the garbage pile?I have a Sony home NETMD unit.Thank you for your help.Lew. Quote Link to comment Share on other sites More sharing options...
SlowMo Posted April 10, 2005 Report Share Posted April 10, 2005 Quote I recently purchased a bunch of used MD's from E-BAY a & when I tried to erase some of them to reuse the message "TR PROTECTED" came up. I was not able to ease the MD so I could use it again....and the write protection slider is in the right position, right ? Quote Link to comment Share on other sites More sharing options...
BobS Posted April 10, 2005 Report Share Posted April 10, 2005 These have been recorded from SonicStage which sets a bit to keep the tracks from being erases. If you have access to an older MD unit (I use my MDS-JB920) it will ignore the TrPrt and erase the disc anyway. Quote Link to comment Share on other sites More sharing options...
pureangst Posted April 11, 2005 Report Share Posted April 11, 2005 check my stickied post in the netMD forum, I describe how to blank the disc in service mode. it works! lewpei said: I recently purchased a bunch of used MD's from E-BAY a & when I tried to erase some of them to reuse the message "TR PROTECTED" came up. I was not able to ease the MD so I could use it again. What I want to know if there is any way I can erase these MD's for reuse or are they junk only fit for the garbage pile?I have a Sony home NETMD unit.Thank you for your help.Lew.← Quote Link to comment Share on other sites More sharing options...
WhACKO Posted September 5, 2006 Report Share Posted September 5, 2006 Where is your post??? I can't seem to find it!!!! Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 5, 2006 Report Share Posted September 5, 2006 WhACKO said: Where is your post??? I can't seem to find it!!!!Welcome to MDCF.As indicated clearly by the author: pureangst said: check my stickied post in the netMD forum, I describe how to blank the disc in service mode. it works! ---> click here. Quote Link to comment Share on other sites More sharing options...
