No Digital Copy ?
necrotoxico
Or it is a Creative Soundcard or Realtek/nVidia On board sound.
In case of the Realtek, a borked driver is possible,
in case of Creative, it is the manufacturer policing its customers.
No wonder, that some people call Creative 'Uncreative Crap'.
In all other cases, go through the Adjustments in the Control Panel and / or update the drivers.
Switching off some Effects can help as well, especially anything, that has to do with surround sound.
That can decide, if digital out delivers a normal PCM-Signal or if it delivers a Dolby or DTS-Stream.
A MD cannot handle Dolby & DTS.
You could try recording to your hard disk first with something like Total Recorder or Wavelab. Or maybe Audacity.
What you want is software that will record your 'mixed output'. That is, will record the sound that is output to your speakers.
I used to use Wavelab (which came with my soundcard) to record internet radio shows for later playback. This is a digital recording of course.
When recorded to .wav, you can then send to MD via SS.
I think.
I think.
thanks man but I just was trying to test the optic recording ...for no specific reason
thanks
