Just Back From Japan With Rh-10
dazzjazz
Hi all,
I got my RH10 last week in Nagoya for the equivalent of $400 aussie dollars.
I'm very impressed with it. The screen makes it easy to use (once I changed the language to English that is!)
I recorded my last gig in Japan with it and it sounds good - I used PCM mode.
The AC adaptor is 110-240v switchable and very lightweight.
On the down side it doesn't remember Rec Mode settings, which is a slight pain.
Nor does it have the clock/timestamp feature that I found handy on my MZN10.
I will endeavour to answer your questions once I get over the jet lag.
Dazzjazz
Guest NRen2k5
How long is the interval of silence between the end of one MP3 and the beginning of the next?
Does the RH10 seem to cut off a tiny bit of the end of the MP3 played?
  bmanalansan said:
Is it true than RH10JE can still record true SP, LP2 and LP4 without using sonic stage?
I heard that the US version does not allow you to record these formats except through Sonicstage.
If it still does, i will buy the JE version.
thanks.
No. I cannot find these older codecs on the Japanese edition.
Just PCM, Hi-SP and Low-SP
dazzjazz
