Gokce Posted April 18, 2005 Report Share Posted April 18, 2005 AA rechargable batteries evolved from 800mAh up to 2500mAh.. Why don't they develop higher capacity gumstick batteries for minidiscs? After all both are NiMH..This lousy battery only lasts for a few hours and almost useless for Hi-MD recording with my 910... Quote Link to comment Share on other sites More sharing options...
malheuresement Posted April 18, 2005 Report Share Posted April 18, 2005 AA rechargable batteries evolved from 800mAh up to 2500mAh.. Why don't they develop higher capacity gumstick batteries for minidiscs? After all both are NiMH..This lousy battery only lasts for a few hours and almost useless for Hi-MD recording with my 910...←Don't know if the 910 uses the same gumsticks as the nh900, but have a look at this thread for some links to alternatives to the NH900 gumstick, plus stand-alone chargers.Any help?mal. Quote Link to comment Share on other sites More sharing options...
Artstar Posted April 19, 2005 Report Share Posted April 19, 2005 AA rechargable batteries evolved from 800mAh up to 2500mAh.. Why don't they develop higher capacity gumstick batteries for minidiscs? After all both are NiMH..This lousy battery only lasts for a few hours and almost useless for Hi-MD recording with my 910...←Which is why I've only ever stuck with devices that use lithium ion/polymer batteries - longer running time, lighter and no memory effect.I love my NH1. Quote Link to comment Share on other sites More sharing options...
Gokce Posted April 24, 2005 Author Report Share Posted April 24, 2005 Thanks a lot for the responses and the link.. Helps a lot.. Which is why I've only ever stuck with devices that use lithium ion/polymer batteries - longer running time, lighter and no memory effect.I love my NH1.← Quote Link to comment Share on other sites More sharing options...
erictioh84 Posted April 28, 2005 Report Share Posted April 28, 2005 as i know, there is a higher capacity battery which is 1350mah. Quote Link to comment Share on other sites More sharing options...
Silvadragon Posted May 3, 2005 Report Share Posted May 3, 2005 (edited) yeah my 1350mah does my fyn, gives me extra hours.I'm not complaining *im a MZ-NH900 user*Oh yeah, did it ever occur to you that AA batteries are bigger in size *duh*But then the AA squashed flat may also b the same size as the gumstickDunno... Edited May 3, 2005 by Silvadragon Quote Link to comment Share on other sites More sharing options...
Christopher Posted May 3, 2005 Report Share Posted May 3, 2005 But then the AA squashed flat may also b the same size as the gumstickDunno... ←Don't go any try this, please! Quote Link to comment Share on other sites More sharing options...
