Woodgnome Posted April 25, 2005 Report Share Posted April 25, 2005 Just got a RH10.No custoomizable Graphic Equalizer on the European Model.Anyone know the hack to get into RH10's maintenance mode and turn the European setting off thus allowing the two customizable Graphic Equalizers.Any help greatly appreciated as the units sounds quite average with the 4 fixed graphic presets. Quote Link to comment Share on other sites More sharing options...
MDfreak Posted April 25, 2005 Report Share Posted April 25, 2005 Just got a RH10.No custoomizable Graphic Equalizer on the European Model.Anyone know the hack to get into RH10's maintenance mode and turn the European setting off thus allowing the two customizable Graphic Equalizers.Any help greatly appreciated as the units sounds quite average with the 4 fixed graphic presets.←I read the manual and indeed the European model does not have the custom settings. This makes it impossible to adapt the sound of the RH10 to the headphones you use. This makes the RH10 pretty useless when wanting to to adapt it to your own taste of sound.I hope the regional codes for the new generation appear quick otherwise I have to reconsider buying a Europan RH10 (maybe get a Japanse one). Quote Link to comment Share on other sites More sharing options...
SlowMo Posted April 25, 2005 Report Share Posted April 25, 2005 bummer.-but on second thought... [-insert rant here-] Quote Link to comment Share on other sites More sharing options...
Christopher Posted April 28, 2005 Report Share Posted April 28, 2005 Your welcome.http://forums.minidisc.org/index.php?showtopic=9752 Quote Link to comment Share on other sites More sharing options...
