Transfer Mp3 To Himd/sb, Ss
El Eddie
I know it been asked before but still ...
Please, Is there any way to transfer mp3 to md without installing SS?
Does SB also tranfer mp3 files to MD?
Can I transfer mp3:s as many times I want to MD?
Simple Burner, does it only rip original cd:s?
transfer mp3: record via optical or analog cable, but that's realtime only. you'll only have the codecs that are available on the unit.
you can tranfer your mp3 from pc -> md as often as you wish. md -> pc is only to source pc.
rip cd's with sb: you can even rip from mounted images, and if you're lucky, cddb recognizes the album and enters the titles correctly..
->sb only reads audio cds, (no matter if burned or original) but you can burn mp3 to an image, mount it to a virtual drive, and there you go.
