Sonic Stage 3.1 And Vbr Mp3s
monkenstick
I just downloaded sonic stage to check it out prior to the arrival of my rh910 player in the mail
i've noticed a problem - sonicstage 3.1 doesn't recognise vbr mp3s properly
it says that they're 128kbs, and even worse - playback is riddled with artifacts
has anyone else noted this? or is it some bug with my codecs?
its going to be very annoying if I can't find a fix
SonicStage does have problems with VBR-files, especially when you had used Lame with the less common options.
Solution: Use Lame to decompress to wave, then import the resulting Wave files or use dbPowerAmpComverter to convert into WMALossless, so your ID3-tags stay alive, then import into SonicStage. Since WMALossless is lossless as the name implies, you still only converting from one lossy codec into another one.
dbpowerampConverter is here:
http://www.dbpoweramp.com/
However, before mass converting now, wait for the actual recorder to arrive and check, how the decoder in the RH910 handles your files, it might sound differently to SonicStage.
SS should have no problem with VBR MP3's, I think the problem lies with some encoders that don't write the metadata accordingly (things like average bitrate and playing time). You can try to fix the headers with a little tool called VBRfix, or the "Fix MP3 header" function in Foobar2000.
EDIT: I just did a test, importing a VBR MP3 file that I've ripped using EAC and LAME --alt-preset standard. The original file played back well and conversions to LP2 and LP4 gave no problems. The bitrate of the MP3 file displayed was wrong, however (128 kbs where it should've been an average of 211 kbs).
Edited by bug80
Hello bug80, I also use EAC+LAME aps to make my VBR MP3s, and they seem to go through SS 3.1 no problem and play ok on my NH900 at LP2 or HiSP.
In fact I've just made a ES 74 min minidisc full of wonderful Blues tracks. I managed to get 60+ tracks on the disc at LP2. They are playing sweetly smile.gifsmile.gif
Sorry, I posted the same problem in the HiMD forum and it was moved here so I'll comment in this thread.
My VBRs are all encoded using LAME and apparently it doesn't, or at least didn't used to, write the VBR header information correctly. Described here LAME VBR header problems Thanks bug80 for the info.
Edited by rubadubdub
Did you use an external (windows) program which calls lame.exe, or did you do it manually (i.e. running lame.exe from a DOS box)?
I guess it depends on what frontend you use. For instance, when I use WinLAME as a frontend for LAME, the headers aren't written correctly. However if I use foobar2000 or EAC, this doesn't happen. I think most of the time, headers written by lame.exe (or lame.dll) are overwritten by the frontend program you use.
I pretty much always use CDEX with LAME. Tried VBRFIX but it didn't help.
Tested VBR MP3s and they will convert and transfer if I specify an ATRAC less than 132kbps but are just transferred if set to 132kbps or higher (my VBR MP3s are all listed as 128kbps in Sonicstage). I don't want to use anything less than ATRAC 132kbps.
Anyway to force SonicStage to recognise these VBR files as higher than 128kbps? I really don't want to reencode them.
Hi,
Along the same lines, I have noticed that my SS 3.1 has a pb with WAV files encoded using TotalRecorder 5.1 Standard Version (I have not tried any other encoders though).
Baiscally, everything "looks" fine until SS reaches 99% of data conversion, at which point iSS seems to enter an endless loop (remains stuck at 99%, the weird thing is that SS still consumes all the CPU at that point in time). The only remaining option is to abort the conversion process.
Has anybody experienced the same pb ? The weird thing is that SS 3.1 is perfectly able to play the very same WAV files with no artifacts, etc., which makes me think that TotalRecorder is off the hook for that pb.
Just adding to a long list of complaints on SS 3.1...
NB: does anyboy know why TotalRecorder does not offer higher than 56kbps quality when recording in MP3 ? This is the reason why I initially wanted to record in WAV, to have higher resolution.
Edited by Jeffy
