Jeff DLB Posted May 10, 2005 Report Share Posted May 10, 2005 I have a pair of full-size mics (Nakamichi CM-300). Is it possible to use them with a minidisc recorder when the situation warrants it? They have better Max SPL (138dB vs 105dB) and dynamic range (114dB vs 76dB) than the very nice, very small SP-BMC3s I just bought. The Naks are powered by a battery in each mic and have an XLR plug on the end. If I had the appropriate adapter, could I use these with the MD (Sony MZ-NH10)? Would they go to Mic In or Line In? I'd like to experiment, but I don't want to fry my new toy.-Jeff DLB Quote Link to comment Share on other sites More sharing options...
ozpeter Posted May 10, 2005 Report Share Posted May 10, 2005 I would expect them to go into the mic input with no trouble, other than having to make up the appropriate adapter. As I've said before, the simple way of doing that is to purchase a 3.5 stereo to 2 x rca lead, chop of the rca plugs and replace with xlr's - saves fiddly soldering of the 3.5mm plug.The only type of mic not immediately suitable for use with minidisc is one requiring phantom power. In that scenario you are bound to have to go via a suitable power supply or mixer, and in the case of a mixer you'd be using line in to the MD. Quote Link to comment Share on other sites More sharing options...
milomind Posted May 10, 2005 Report Share Posted May 10, 2005 Jeff DLB said: I have a pair of full-size mics (Nakamichi CM-300). Is it possible to use them with a minidisc recorder when the situation warrants it? They have better Max SPL (138dB vs 105dB) and dynamic range (114dB vs 76dB) than the very nice, very small SP-BMC3s I just bought. The Naks are powered by a battery in each mic and have an XLR plug on the end. If I had the appropriate adapter, could I use these with the MD (Sony MZ-NH10)? Would they go to Mic In or Line In? I'd like to experiment, but I don't want to fry my new toy.-Jeff DLB←Good prices on adapters here.http://www.audiogear.com/Audio-Adapters-Miniplug.html Quote Link to comment Share on other sites More sharing options...
musicguru Posted May 10, 2005 Report Share Posted May 10, 2005 Yes it is possible. I do it all the time with great results. If your mics has can handle phantom power you can get a battery powered phantom power box and will get even better results. It's always better to use phantom power than the battery>Van Quote Link to comment Share on other sites More sharing options...
