determined2bme2 Posted May 10, 2005 Report Share Posted May 10, 2005 Hi,I'm looking for a n710 battery case.Does anyone know if the n910 external battery case fits the n710? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted May 10, 2005 Report Share Posted May 10, 2005 determined2bme2 said: Hi,I'm looking for a n710 battery case.Does anyone know if the n910 external battery case fits the n710? ←All Sony NetMD’s dry battery case is identical and you can certainly use the N910’s dry battery case with the N710. Quote Link to comment Share on other sites More sharing options...
determined2bme2 Posted May 10, 2005 Author Report Share Posted May 10, 2005 Would the dry battery case from a nh900 do the trick? Are Himd the same? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted May 10, 2005 Report Share Posted May 10, 2005 determined2bme2 said: Would the dry battery case from a nh900 do the trick? Are Himd the same?←Sorry, I do not have the NH900, thus can't confirm if its dry battery case is identical to those of NetMDs. However, I can confirm that RH10's dry battery case is not the same as NetMD's dry battery case.If you are looking to purchase MZ-N710's dry battery case, you can order it direct from Sony DAPC for $3.54. The part number is 324589001. Of course, call in (Sony DAPC, 1-800-488-SONY (7669)) and confirm before you conclude the transaction. Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted May 11, 2005 Report Share Posted May 11, 2005 Yes I can confirm the NH900 battery case fits the N910, so should be all right for N710 too. Quote Link to comment Share on other sites More sharing options...
determined2bme2 Posted May 11, 2005 Author Report Share Posted May 11, 2005 Great! Quote Link to comment Share on other sites More sharing options...
jay21pee Posted July 18, 2005 Report Share Posted July 18, 2005 Are all the Sony battery cases universal? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 18, 2005 Report Share Posted July 18, 2005 jay21pee said: Are all the Sony battery cases universal?←A majority of them are universal so to speak. However, 2nd generation units such as the RH10 employs another sort. Quote Link to comment Share on other sites More sharing options...
MDX-400 Posted July 18, 2005 Report Share Posted July 18, 2005 jay21pee said: Are all the Sony battery cases universal?←Most are but there are some exceptions. Most of the units using a 3.6V lithium battery instead of an NiMH gumstick (such as those like the N10 IIRC) use a different connection and there are a few other exceptions (perhaps more now with the Hi-MD units) but for the *most part* they are the same. Quote Link to comment Share on other sites More sharing options...
jay21pee Posted July 18, 2005 Report Share Posted July 18, 2005 I need one to use on my R70 and N510. Quote Link to comment Share on other sites More sharing options...
