Happy Hopping Posted May 11, 2005 Report Share Posted May 11, 2005 IN the PDF file of the NH1 manual, it says under Option, the NH1 can:-) set the clock-) Adjust the contrastNow, these options are simply NOT available on my NH1 under the Option manual. Am I the only one? Quote Link to comment Share on other sites More sharing options...
VikingEP Posted May 11, 2005 Report Share Posted May 11, 2005 The functions are there (at least on my MZ-NH1), but you have to access them via the _remote control_.Hope this helps! Regards, Erik Quote Link to comment Share on other sites More sharing options...
bwerbrou Posted May 11, 2005 Report Share Posted May 11, 2005 maybe the menu mode is set to simple in stead of advanced? Quote Link to comment Share on other sites More sharing options...
Happy Hopping Posted May 11, 2005 Author Report Share Posted May 11, 2005 bwerbrou said: maybe the menu mode is set to simple in stead of advanced?←I have it at Advanced, but I was using the main unit, not the remote, because I am not quite clear how to use the remote to get to the Option menu.Let me try it again, thanks guys. Quote Link to comment Share on other sites More sharing options...
Damage Posted May 13, 2005 Report Share Posted May 13, 2005 Stop the unit during playback (to be sure) to set the clock.The contrast adjustment feature refers to the RM-MC40ELK's contrast, not the on-unit LCD.Both can be accessed by accessing the menu from the remote (holding down the jog wheel for a sec), then scrolling down to OPTION in the menu. Quote Link to comment Share on other sites More sharing options...
Happy Hopping Posted May 17, 2005 Author Report Share Posted May 17, 2005 Damage said: Stop the unit during playback (to be sure) to set the clock.The contrast adjustment feature refers to the RM-MC40ELK's contrast, not the on-unit LCD.Both can be accessed by accessing the menu from the remote (holding down the jog wheel for a sec), then scrolling down to OPTION in the menu.←Thanks, I did it. Somehow I wasn't able to do it earlier w/ the main unit. Now I know there is nothing wrong w/ my unit.thank you very much for the info. Quote Link to comment Share on other sites More sharing options...
