Haybrd Posted May 16, 2005 Report Share Posted May 16, 2005 Hi. I imagine this has been asked a thousand times before but....Does Hi MD support AAC format? If not, is there software available that will convert it to a useful format?many thanks in advance! Quote Link to comment Share on other sites More sharing options...
bug80 Posted May 16, 2005 Report Share Posted May 16, 2005 Sonicstage, the program you have to use for transferring files to Hi-MD, doesn't support AAC. So, you have to convert to a usefull format first. The best choice is WAV, that way the number of transcoding steps (from one lossy format to the other) is the lowest.Programs that can do that are for example dbpoweramp, foobar2000 and possibly iTunes, as long as the files are not DRM-ed.If they are copy protected, you have to burn an audio CD first and after that rip the files back to your PC. Quote Link to comment Share on other sites More sharing options...
Haybrd Posted May 16, 2005 Author Report Share Posted May 16, 2005 Thanks Bug80! You are a star! Quote Link to comment Share on other sites More sharing options...
