Slinky Nandita Posted June 3, 2005 Report Share Posted June 3, 2005 Need help please. I borght a Sony digital microphone to attatch to my Sony MD/MZ-N505 Type R. The problem is I'm not sure where to attatch it, into the optical line in or into the headphone line? Also not sure how to operate as there are no instruction for this operation in the manual for my MD It would be so great if anyone could help me as the microphone costed me $190- and I've been waiting to use it to record sounds from nature to mix into my techno that I mixed it will sound so great if I ever get it working. If my model does not support the mic I'm willing to buy the model that will support it. I have a great knowledge of rebuilding computer hardware so I can be very helpfull if anyone needs advice on installing new memory modules/cd roms etc...someone please help and I will be forever gratefull. Quote Link to comment Share on other sites More sharing options...
greenmachine Posted June 3, 2005 Report Share Posted June 3, 2005 Your recorder has no 'mic in' jack, you need either a different recorder with a built-in microphone preamplifier or an external microphone preamplifier plugged to 'line in' of your recorder. Quote Link to comment Share on other sites More sharing options...
A440 Posted June 3, 2005 Report Share Posted June 3, 2005 Look in the Browser tab at the top of the www.minidisc.org page. Sony models with Mic-in: MZ-RH10, MZRH910, MZ-NH900, MZ-NHF800, MZ-NH700, MZ-NH1. These are all Hi-MD models that will allow you to upload recordings to a PC. Reguar MDs with mic jack--which do not upload, but you can record analog out of the headphone jack--include MZ-N920 NE810 NF610 NF810 N910 N710 N707 R900 and R700. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 3, 2005 Report Share Posted June 3, 2005 A440 said: Look in the Browser tab at the top of the page. ←this 'browser' tab gets mentioned quite often in 'find your minidisc'-threads... I was just wondering, am I going blind or haven't I got a browser tab? Quote Link to comment Share on other sites More sharing options...
A440 Posted June 3, 2005 Report Share Posted June 3, 2005 The Browser tab at the top of the minidisc.org homepage. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 3, 2005 Report Share Posted June 3, 2005 A440 said: The Browser tab at the top of the minidisc.org homepage.←ah that explains a lot, I do know where that one is thanks A440, you really know everything Quote Link to comment Share on other sites More sharing options...
shig420 Posted July 8, 2005 Report Share Posted July 8, 2005 I had a 505 and had to upgrade to a 707 for recording with my sony mic. I have a 907 sony mic, It has a AA batt included for a little bit of boost, but it's not going to be enough to record nature sounds.You can only record really loud music on the 505 via the line in (which is both optical and analog 1/8")I might strongly sugest a new Hi-MD (with a mic and line input, of course). They start at 199 and are totally worth it. You can use old dscs, and use it as a USB storage device up to 1 GB with the new discs (300MB with the regular old discs.)I just ordered an open box one from minidisco.com to replace my old units.The greatest thing is that you don't have to plug the headphone line into your PC's audio card with all that hissing ant intereefierence. You can now uploaad music recorded from your mic directly to the PC using teh USB.I'm totally psyched to remaster all of my old recordings in total digital lovin' Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted July 8, 2005 Report Share Posted July 8, 2005 welcome to MDCF shig420,nice to see someone all excited about Hi-MD...it is a fine format indeed shig420 said: The greatest thing is that you don't have to plug the headphone line into your PC's audio card with all that hissing ant intereefierence. You can now uploaad music recorded from your mic directly to the PC using teh USB.I'm totally psyched to remaster all of my old recordings in total digital lovin'but just a slight reminder... you do realize that you won't be able to use the USB-uploading method for your old recordings?all pre-HiMD recordings and also SP/LP2/LP4 recordings on MD-formatted discs made with the HiMD-recorder are still only uploadable in realtime through the line out/headphone out (analoguely) or optical out (digitally) if you have got a deck which has one... but no USB-uploadingsee this stickied post and this one for a more detailed explanationgreetings, Volta Quote Link to comment Share on other sites More sharing options...
