Uninstall Rh10 Driver
dazzjazz
also, if you don't mind a bit of extra work, you could try this workaround which you would have easily found yourself if you had read /searched the older/other posts in the 'Software discussion/FAQ's'-section a bit...
please remember, knowledge requires effort so please search before you ask (the same question that has been addressed so many times before)...
Greetings, Volta
