Whats A Good Music Composing Program?
lukej101
Im trying to find a good program that lets you create music (the type of program where you have one line and create a beat and another for lyrics and so on). If anyone can reccomend something that is not to hard then i would be really grateful. Im willing to spend the £300 that these things can cost.
i'm using reason, and am very satisfied.
the cool thing about it is, that all funktions are visually available, if you don't know the use of a certain knob - use it, and you'll see.
automation is also very easy to use on this one.
reason is perfect for use with midi devices, i use a doepfer pocket dial and it's a pleasure...
reason basically acts as a virtual studio rack, with samplers, synths etc. check http://www.propellerheads.se for details...
