Playback Problem
After a long weekend of live recording (through line-in) in PCM mode,
my 8 hours of recordings on 6 HiMD Sony Discs have a playback problem.
The tracks play and can be ffwd/rew, etc as expected through the middle of each disc.
After about 45 min., playback is spotty at best, with the time readout stopping for
a few seconds, or even minutes, before play picks up, sometimes accompanied by
a loud static burst.
This is consistent over 6 HiMD's.
This unit is 6 months into it's warranty (extended for 3 years total)
but I'd do anything not to have to send this player away.
Any ideas?
Thanks-
I have the same problem when it's plugged into the AC adapter.
I'm on a Mac so don't use the sonicstage software.
I'm afraid to send it back to Sony, as I've heard horror stories about waiting 2-3 months for the unit to be returned and still not repaired.
Also, the unit will play regular MD discs fine all the way through.
I recorded 6 HiMD Sony discs @ PCM mode and every one starts
skipping , hissing and just plain stalling out after about the 45th minute
(out of 94).
The skipping, hissing and stalling is never exactly the same twice.
I emailed guySonic who suggested I may have lucked into a bad
batch of HiMD Discs.
Sure enough, when I play back regular MD's or an older HiMD I bought
a few months ago, they play just fine.
Any ideas on how to get at least my money back for the 8 Bad Discs I bought?
Good thing these sessions were recorded also on ADAT and DAT (mine is the 2nd backup)
- KP
Hi kpayson. Try to contact support at the Sony website to see if you can get some money back for your bad discs. I've also got an MZ-NH1 and I've had several (3 or 4) Hi-MD discs go bad on me...all from different batches and different ranges of serial numbers on the back. My experience with Hi-MD discs is that they are not overly reliabe, and it seems that the more a Hi-MD disc gets reused, the less reliable it becomes. It's a good thing you had backups of your recording.
