JWCompany Posted July 10, 2005 Report Share Posted July 10, 2005 Hello,I think I read somewhere on the board that if I have an mp3 with 192kbits I won't be able to encode it to Atrac3+ 256kbits. Basically, that I cannot choose a higher Atrac3+ bitrate than the source mp3 had.Knowing SonicStage this is probably true. Is it however possible with any other software?Thanks,J.W. Quote Link to comment Share on other sites More sharing options...
greenmachine Posted July 10, 2005 Report Share Posted July 10, 2005 Decode the mp3s to wav beforehand and SS should convert it. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted July 11, 2005 Report Share Posted July 11, 2005 it always decodes the music file to PCM before rencoding it as Atrac. The Atrac bitrate only determines how much information is retained out of that new PCM audio Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted July 11, 2005 Report Share Posted July 11, 2005 GIGO - garbage in, garbage out.The two chief caveats are:* If you transcode something that's low-bitrate, you can't improve the quality, you can only hope to retain the current quality. Transcoding to a higher bitrate than the current one [256kbps atrac3plus from 192kbps MP3] should retain nearly the same quality as the original* Some MP3s from some encoders can't be transcoded correctly by SS; my experience with this is very hit-and-miss, not consistent even with material from the same encoder .. so it's a guessing game at best as to whether you'll end up with music or simply silence from your MP3s. In any case, converting to WAV or lossless WMA [which should retain tags, unlike WAV] and then converting that to atrac/3/plus using SS should work. With whole albums of 'naughty' MP3s [ones that transcode as silence, or where some do at least] I usually would create a CD image of them using Nero, and rip that image using Simple Burner, which can then pick up their titles from CDDB. Quote Link to comment Share on other sites More sharing options...
veezhun Posted July 11, 2005 Report Share Posted July 11, 2005 GIGO hahahahahhaahhah LMAO:Dfunniest line i have read in a long time... strangely was reading about stock valuations on a FIFO basis some days ago... GIGO is truly awesomeyou can delete my comment if it adds no value to this thread.. just wanted to laugh Quote Link to comment Share on other sites More sharing options...
