mj23 Posted July 15, 2005 Report Share Posted July 15, 2005 Hi all,First post here and would be really grateful for some help. Got an old Sony MZR700 and not sure which software is compatible. Will SonicStage work? Currently using analogue lead which gives me the MD as 'one track' issue. Any ideas?Cheers. Quote Link to comment Share on other sites More sharing options...
atrain Posted July 15, 2005 Report Share Posted July 15, 2005 sorry your md is pre netmd protocol. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted July 15, 2005 Report Share Posted July 15, 2005 the MZR700 isn't a NET-MD (it hasn't got a USB-port) so you would need an additional PC-connector kit at least to use a PC with ityou could however use the optical in and synchro copy mode...(I believe) as that would add trackmarks... and if your PC has an optical out, you could use that as a source for this, but it wouldn't allow titling anything or soyou can read up on the MZR700 in the minidisc.org equipment browserhope that will clear things upif you are interested in the format, it could be wise to check out the improvements that HiMD has brought with it (just read about it on minidisc.org and here on MDCF) Quote Link to comment Share on other sites More sharing options...
