MDX-400 Posted July 26, 2005 Report Share Posted July 26, 2005 Using SS 3.2 now and encountered a problem where SS doesn't want to convert some MP3 files to anything but silence...I did a search and I've read that some other people have had this problem in the past but didn't see any kind of solution.Is there a solution to this problem?The weird thing is that the files that SS won't convert properly, I can tell before it even converts them that this is going to happen... If I try to play back these MP3s in SS it will play back silence *unless* I skip around in the track--like even if I skip a little ahead or a little behind, using the slider, then it starts to playback fine in SS. However converting files it does this with, results in a complete [ATRAC3] file of silence!What gives? Is there a fix/workaround for this? It isn't really important as I never really use SS to transfer anything (because I don't even use MDLP) but I was just fooling around with it today (since 3.2 was out now) and noticed this foolishness.The funny thing is all the MP3s I'm trying to convert were converted by the same process--LAME 3.90.x with --alt preset insane (320kbps CBR). Some files will convert fine or play fine without "skipping around" and then some don't. You'd think Sony would have that working right by v3.2??? Quote Link to comment Share on other sites More sharing options...
Syrius Posted July 26, 2005 Report Share Posted July 26, 2005 The only solution I can think of is to convert your MP3's to WAV/WMA lossless and import and transfer those. Quote Link to comment Share on other sites More sharing options...
