80 min. disc compatibility
Hello,
I just bought a minidisc player/recorder (Sony MZR900) on E-Bay, and I am thinking about buying a deck unit still from E-Bay since they are so hard to find.
I would like to buy some new minidiscs but I am wondering if the 80 minute ones will be totally compatible with older (1997-2003) players/recorders, either walkmans or decks. Would it be better to stick to standard 74 minutes one? Any sound quality differences between the two?
Thanks a lot and have a great day,
Stephan
Hello,
Stephan
Welcome to MDCF.
You can certainly use the 80min MD Media with your newly acquired MZ-R900. All MD media - 60min, 74min and 80min - are compatible with all MD units regardless if it is a Pre-NetMD, NetMD or Hi-MD unit. As for sound quality - no differences whatsoever between 74min and 80min.
Thank you very much for your response. I am looking for 80 minute ES blank discs but they are very hard to find...especially here is Canada, it looks like they are going out, unfortunately.
Thanks again,
Stephane
Welcome to MDCF.
