Remotes for NH600D and/or RH910
Hi all,
I own the North American (Canadian)versions of the NH600D and the RH910 which do not come with remotes. I am blind so I cannot tell if there is a socket for a remote or not. It "feels" like there is a socket for a "headphone remote" similar to the sockets on my NF520D and NF610. Can I use a remote (do not require AM/FM) with these NA units and if so, where in Canada could I purchase them?
Thanks,
ET.
Almost any Sony remote will work with these two units. The RM-MC40ELK is the preferred but the 35EL will do the job. You can check on ebay or even minidisco for remotes but be aware they are overpriced on most etailer sites. You can get decent ones on ebay for less than $25-$30.
Here is a thread regarding most of the Sony remotes:
Remotes
Good luck.
