MZ-RH10 versus MZ-N1
joplin
Anyhow, the MZ-RH10 is definitely better than the MZ-N1 for obvious reasons - just to name a few: OLED display, updated sound engine and optical block, 1GB Hi-MD capacity and ATRAC3plus.
Nonetheless, I trust you will read more or less positive feedback for the RH10 over the MZ-N1 in the following posts.
Hi
Which of the above is better and why.
How good is Mp3 on the Mz-Rh10?
Any information or feedback would be appreciated.
Thanks
There's no such thing as the 'NZ-N1'.
The MZ-N1 is a NetMD unit which supports only NetMD and not any of the Hi-MD technologies.
The MZ-NH1 (I assume you meant this one?) is a first generation Hi-MD unit which can record in NetMD modes on the unit but can only play back MP3s after they have been converted to ATRAC by sonicstage. It does support Hi-MD blanks and the Hi-SP and Hi-LP ATRAC modes though. The NH1 has a magnesium body construction making it very solid, but has only a 1-line display on the unit and small controls on the unit, with the remote carrying most of the functionality for it.
The MZ-RH10 is a second generation Hi-MD unit which cannot record in NetMD modes on the unit (though can using sonicstage) but can playback MP3s in their native form, without them being converted to ATRAC. There is a high-end filter on MP3 playback though causing a loss in volume in the treble range (it gives the effect of things like symbols sounding a lot quieter on MP3 playback) but in my opinion you can overcome this easily by playing around with the equaliser on the unit (though if you intend to get a European unit you will have to hack it to get the equaliser.) As it is a Hi-MD unit it also supports the Hi-MD modes. In terms of body, the RH10 is plastic with a notoriously easily scratchable aluminium lid but it does have a an organic El LED display which (in addition to being far bigger than the NH1's display) is visible in the dark.
Personally I'd go with the RH10 as I feel it's a better unit (though definitely not for someone who has to do a lot of recording in MDLP for older MD units) and it's also cheaper!
To sum it up:
NH1
+ body
- unlit 1-line display (though with highly functional backlit remote to compensate)
+ NetMD recording on Unit
- cannot play MP3 back in native form
- more expensive
RH10
- body
+ lit 6-line display/better user interface
- no NetMD recording on unit
+ can play mp3 back in native form
+ cheaper
At least, those are the main points I can come up with...
