Looking for a good mic
lalo
There are propably as many (contradictious) opinions about microphones and their placement as there are users. A one-point stereo mic can be incredibly comfortable but won't necessarily give you the most realistic stereo image. Just imagine how you would perceive the world if your ears were that close together.
so are you suggesting binaural microphones?....
the only problem is how to wear those...i do a lot of noise while breathing smile.gif..or just moving....
lalo
I had an AT822 for about a year. Not a bad unit and it's a workhorse. You can use it via the Mic input for acoustic and non-amplified sounds with good results. I would recommend the attenuator cable/connection if you are recording louder music via the mic input. If you are using the Line Input, the levels can be a bit low at times if the source is not that loud.
Here's a Cowboy Junkies show I recorded in 2004 going Mic Input with my Sharp DR7 MD>>> Cowboy Junkies 2004 on the Live Music Archive
It's easy setup and does a good job with loud music. But, the sound field is limited at times and you can't adjust the mic elements to point in different directions. There is no stealthing with this monster. For outdoor use, it's one of the easiest with very little windnoise pickup when you have that windscreen in place.
For a bar setting, it's easy to setup and does a decent job. You are limited in power and direction and stealth options. Maybe consider mini mics with a battery box/preamp instead for more flexibility. Try Reactive Sounds or Sound Professionals for the best selections...
for mini mics..do you intend binaural ones?
thanx
Cardiods have their merits since they tend to roll off some bass by design of the pattern and you get less crowd chatter than omnis but omnis are great for stealth and outdoor use.
