FergusF Posted August 25, 2005 Report Share Posted August 25, 2005 Hi all,I recorded a voice interview on a Panasonic walkman type tape recorder before I got my rh-10 last week. I connected the headphone socket on the tape recorder to the line in on the rh-10. I monitored the quality on headphones on the rh-10. There was a terrible hum during the recording that was not on the original tape. I tried the same operation a 2nd time and the hum was not as bad.I have the sound setting set to normal and the record setting is set to hi-sp.Is there something that I am missing? are there other settings that I should be setting?thanks in advance,Fergus Quote Link to comment Share on other sites More sharing options...
greenmachine Posted August 25, 2005 Report Share Posted August 25, 2005 Using the external power supply introduces unwanted hum if recording through the analog inputs. Use a battery instead. Quote Link to comment Share on other sites More sharing options...
FergusF Posted August 25, 2005 Author Report Share Posted August 25, 2005 Using the external power supply introduces unwanted hum if recording through the analog inputs. Use a battery instead.←Hi Greenmachine,thanks for that, you are right, removing the ext power supply got rid of the hum, thanks a lot.Fergus Quote Link to comment Share on other sites More sharing options...
greenmachine Posted August 25, 2005 Report Share Posted August 25, 2005 At your service Quote Link to comment Share on other sites More sharing options...
