Broken Jog Wheel...
Rowan
unsure.gif So has anyone else had problem with the jog wheel on the MZ-NHF800? The other day I realise that my jog wheel would only work it I pushed down on the bottom section.
So... it still kind of works, but is effectively broken. Anyone have any experience with this or do I have to go to a service center?
Rowan
Edited by Rowan
  Rowan said:
:unsure: So has anyone else had problem with the jog wheel on the MZ-NHF800? The other day I realise that my jog wheel would only work it I pushed down on the bottom section.
Rowan
I don't have that problem on my NHF800, but If I spin the weel too quickly it wont work.
All I can suggest is check if the minidisc player is still in warrenty or use your suggestion...
I hope you find a solution.
~Danny
