MZ-N710 (with all accessorys) for £10!
Embio
I have just bought my 2nd MD unit! I got fed up with having to wait for radio or vinyl recordings to finish before I could listen to stuff I only have on MD. So now the N710 can handle all that, £10 - off a mate who is upgrading to a HD player - with all the accessorys. Few issues though:
1, The main 4-way button in the middle of the unit is loose (any way to fix this?)
2, The battery only lasts for 3 hours (didnt I read of a way to 'recondition' Ni-MH batterys?)
3, A quick jerk will turn the unit off (this isn't that big a problem as the unit isn't going to be used portably)
any ideas on how to fix these problems would be greatly appreciated - its mainly point 3 that is the real issue.
cheers
--> either: 1) obtain a service manual and perform your own repair with reference to its schematics or 2) send it to your local Sony Service Center or an authorized MiniDisc workshop.
--> try using a brand new NiMH and check if there's any improvement over the existing battery.
--> a connector must be loose within. Either: 1) obtain a service manual and perform your own repair with reference to its schematics or 2) send it to your local Sony Service Center or an authorized MiniDisc workshop.
*thread moved to NetMD section of the forum.
A few full discharge-charge cycles (let it play until it shuts off automatically) should do the trick, if the situation doesn't improve, it's time for a new battery.
