brendanhm Posted September 29, 2005 Report Share Posted September 29, 2005 Device Not Reconized-MZ-NF520DYa so basically whenever i plug the usb cable into the MD and USB port nothing happens, I have downloaded the PA drivers from this site and Im pretty sure the USB cable is ok. PLease help Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 29, 2005 Report Share Posted September 29, 2005 Hello there, and welcome! State your system specs according to the rules and also, you may want to try reinstalling via the directions in the FAQ. Quote Link to comment Share on other sites More sharing options...
brendanhm Posted September 30, 2005 Author Report Share Posted September 30, 2005 system specs:XP-SP2P41.8GHz9200se PCI cardwhat else???What would you have me reinstall? Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 30, 2005 Report Share Posted September 30, 2005 Oops. I'm going to move this to the Software forum, go ahead and read the rules and FAQ there. Quote Link to comment Share on other sites More sharing options...
brendanhm Posted September 30, 2005 Author Report Share Posted September 30, 2005 ok, and BTW when I insert the USB into the MD it starts humming so thats how I figure the cable and MD are ok, but the computer does not detect it.ok ive read the FAQ, and i cant seem to be able to find anything about the computer not detecting the netMD Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 30, 2005 Report Share Posted September 30, 2005 Follow the directions about reinstalling. Quote Link to comment Share on other sites More sharing options...
brendanhm Posted September 30, 2005 Author Report Share Posted September 30, 2005 done that now what?? thanks for your help so far BTW ok i uninstaled all Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 30, 2005 Report Share Posted September 30, 2005 Install Sonicstage 3.2. Quote Link to comment Share on other sites More sharing options...
brendanhm Posted September 30, 2005 Author Report Share Posted September 30, 2005 ok SS3.2 is installing but in meantime...why did this happen?after SS is installed then what?what if my cpu still does not detect it? Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 30, 2005 Report Share Posted September 30, 2005 There's too many variables for me to list as to why this could be happening. Make sure that the unit is plugged into the computer's USB port, and not a USB hub. ALSO, ONLY PLUG THE UNIT BACK IN WHEN EVERYTHING IS INSTALLED. If it doesn't detect it, we'll go from there. Quote Link to comment Share on other sites More sharing options...
brendanhm Posted September 30, 2005 Author Report Share Posted September 30, 2005 ok installation is complete, before i plug in USB please tell me what USB I should put it into?? LIke how do i tell the difference?...still doesnt work the computer does not detect still i have just opened up a brand new cable as well (usb) Quote Link to comment Share on other sites More sharing options...
brendanhm Posted September 30, 2005 Author Report Share Posted September 30, 2005 ..............................................still solution Quote Link to comment Share on other sites More sharing options...
raintheory Posted September 30, 2005 Report Share Posted September 30, 2005 (edited) You could try downloading and installing the "Sony Personal Audio Driver" from the Downloads section of the forum.EDIT: When you say that the device is not recognized, do you mean it doesn't appear in SonicStage when you click on transfer? Are you trying to access the unit from windows directly? If you are attempting to access the NetMD from windows explorer, it will not show up anywhere, only the HiMD units show up as a removable disk in Windows Explorer. Edited September 30, 2005 by raintheory Quote Link to comment Share on other sites More sharing options...
ushalit Posted October 1, 2005 Report Share Posted October 1, 2005 raintheory said: You could try downloading and installing the "Sony Personal Audio Driver" from the Downloads section of the forum.EDIT: When you say that the device is not recognized, do you mean it doesn't appear in SonicStage when you click on transfer? Are you trying to access the unit from windows directly? If you are attempting to access the NetMD from windows explorer, it will not show up anywhere, only the HiMD units show up as a removable disk in Windows Explorer.I have the same Problem with NetMD NF-610. Did everything mentioned in the thredas- uninstalled according to FAQ, Installed 3.2 twice - nothing. The unit is connected to a USB port, not a hub In one of the threads, there was a workaround which seemed to work for many members, installing a german version and then 3.1. But the German version is no longer available. Does anyone knows where to get it? Quote Link to comment Share on other sites More sharing options...
skmetal07 Posted October 16, 2005 Report Share Posted October 16, 2005 hey guys, im having this same problem. sonicstage says that there is no device/media connected, i've tried everything (uninstalled, reinstalled, ect). but simple burner recognises it right away, and i can edit and move tracks around.933Mhz, 512Mb, Radeon 7000 (recent drivers installed), Xp Home Quote Link to comment Share on other sites More sharing options...
