Scarbo Posted October 1, 2005 Report Share Posted October 1, 2005 I use my model 910 HIMD *only* for making field recordings, mostly in PCM format. I download them easily with SonicStage 2.3, then convert them with Sony's WAVE Conversion tool. This all works fine, and I am wary of fixing something that isn't broken. Is there some compelling reason I should upgrade to SS 3.2, using the stripped file posted here? Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted October 1, 2005 Report Share Posted October 1, 2005 how about unlimited uploading of your own recordings (as opposed to one time only with all earlier versions) and the option to automatically convert the uploaded files to wav with the internalized wav-converter (since version 3.0) Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted October 1, 2005 Report Share Posted October 1, 2005 how about unlimited uploading of your own recordings (as opposed to one time only with all earlier versions) and the option to automatically convert the uploaded files to wav with the internalized wav-converter (since version 3.0)If you can do without unlimited uploading then why fix something that isn't broken? I used 2.0 for quite a while after 3.0 was out. I upgraded to 3.0 when I found I could not do something I wanted to do. I am still on 3.0. I'll upgrade when it breaks or I really feel that 3.2 has something I need. Quote Link to comment Share on other sites More sharing options...
Syrius Posted October 1, 2005 Report Share Posted October 1, 2005 What Volta is trying to say is that SS 3.2 offers you the security of trying again in case your upload gets botched WITHOUT SS denying you any further attempts or erasing your discs, like SS 3.0 and previous will. Better safe than sorry. Quote Link to comment Share on other sites More sharing options...
