RH10 hack
Alexx
normally speaking you should be safe unless you press the save button (with the 1st gen service mode it was pause, don't know what it is with 2nd gen, though that should be mentioned in the thread somewhere) if something doesn't seem right, simply disconnect all power sources (ac-adapter and all batteries) and wait half a minute and just start her up again, you should be in normal mode again without any changes made... this said, service mode can be dangerous so stick to the hack and do not change things as an experiment and realize that MDCF nor I can be held responsible for any faults :P
how do i know if my MZ- RH10 is a 1st or 2nd generation
  Alexx said:
esspecially low volta for her continuing support :P
hey thanks, glad to have helped... but last time I checked, I still was male (although the belly is starting to block some things from view :lol: just kidding... but I'm a guy really, just check my personal picture)
:D sorry m8- Thanks all the same
  Ishiyoshi said:
I'm glad you find the area code helpful; however, there's no need to create another thread when you have an existing one about it.
AS I said NO ONE had replied to it as its like years old!!!
Well thank you for pissing on my party! <_<
*goes back to the now fully functioning MD player*
*Playfully smacks your bum*
  Poodle said:
Instead of creating a new thread and annoying a mod, you could always use the BUMP 'facility'... ;):rolleyes:
Although that might be equally frowned upon.
but when I replyed to the thread it was bumped :(
no one listened to little me though even though there was an extra 21 views of the topic :rolleyes:
