Problem: "SonicStage setup terminated"
ballsandy
Judt recently i found out that there was an upgrade for sonic stage.
I downloaded it and expected a successful installation but that was not the case.
Just after it apparently completed the uninstall of the old sonic stage i get a screen that says that the upgrade was terminated. I re downloaded the upgrade with the same result.
What possibly is wrong?
I reinstalled sonic stage v2.0 form the cd thaty came with my MZ-N20D and the same result.
Any help?
oh, sorry.
The sonic stage download still did not work so here is my sys info:
Windows 98 SE with all updtaes and packs
sonic stage ver 2.0
somple burner ver 2.0
nimo codec pack and divx codec
sony MZ-N420D minidisc player and sony MZ-N505
500 mhz cpu (amd)
128 mb ram
4 mb video card
usb 2.0
tape drive
dvd drive
zip drive
ditto drive
latest version of directx
all but explorer were closed via the control, alt, delete screen.
does this help?
for codecs intsall divx & an xvid binary like nic's on thier own. codec packs are for suckers. any other audio codecs can be installed individually too.
Ffdshow is the only one that isn't a bunch of codecs and it is way much better then xvid and divx and ac3 filter.
Why should it cause problems to SS 3.2 ?
first of all:
I tried ss 3.2 but it did not work.
second, the links to the download-free full of ss 3.x lead me to the 700 k file.
third, i know those codecs are causin no trouble but i will remove them anyways.
and fourth, i have completely removed sonic stage and all it's components from my computer and am waiting to find out what to da next.
If you have a broadband connection then go to www.connect.com and install 3.2 from Sony's online installer. Second best is to use the offline installer from the Downloads tab.
Even if the codecs are causing no trouble elsewhere SonicStage may not like them. It doesn't play well with the other children.
eyal knaany, there is no "why" with sonicstage. It just does what it does.
okay, i removed the codecs and and am now getting ready to install ver 3.2.
I will tell you what happens.
oh, and i am guessing that i have to reinstall sonic stage first form my supplied cd because i am guessing the download is an upgrade.
never mind.
connect.com is offline in my area.
I gotta wait.
Anyways, is the download from connect.com a full version of sonic stage or is it an upgrade?
I know I'm clogging up the thread, (sorry ballsandy, and I totally sympathise with things not working).
But A440 you've totally made my day with this statement! ;) Classic!
i tried the install again and still the same result.
I also might of found out what is wrong.
First, as mentioned, my computer is running at 398 mhz and is operating on windows 98 se.
Probably the below-minimum cpu is causing the failure and since i am using windows 98 they might of accidentally said it would work when it does not.
I will try once more and then i will just give up and see if you can figure it out along with sony support.
:lol: SUCCESS!!! :lol:
...Well, almost. When reinstalling sonicstage from my cd i noticed that a folder was not created in the start menu. This means i can not use norton clean sweep to remove it so i used add/remove programs and after a very fast uninstall i checked sonic stages folder. This is where it gets interesting. Even though i uninstalled sonic stage it was still in it's folder and ran fine. So i am guessing that when the upgrade tried to install ver. 3.2 i finds the older version in it's place so it stops the install.
Now i gotta find how to completely remove sonic stage and then i will be able to once again use my minidisc player!
Now... how do i remove a program that will not uninstall itself and can not be removed by clean sweep?
