How do I adjust the recording level on previous recordings?
MiniDiscist
If you were trying to record loud music or music with strong bass, the preamp on the MD probably overloaded. Once you get that distortion and clipping it can't be removed.
To get better recordings of loud sounds, here's an inexpensive trick.
http://forums.minidisc.org/index.php?showtopic=9069
And here are some basics:
http://forums.minidisc.org/index.php?showt...993entry49993
I've tried this by 'tweaking' a very heavily distorted concert using Audacity and found it very frustrating (even upsetting!) as I've never achieved satisfactory results.
That said, I'm rubbish at using Audacity (if anyone knows of an idiot's guide, please inform). I've found that the only solution is to get better at live recording - but this doesn't help you much I'm afraid!
