Creating albums for own recordings
spade
Hi,
I have an MZ-NH1 and SonicStage 3.2 under Windows XP Pro SP2.
After several month the album "Transferred from HiMD" has become very crowded. I now want to create some new albums and move titles from "Transferred from HiMD" to them. I have chatted with a support technician, who, knowing that I am using SonicStage 3.2" pointed me to a page for 2.3 where they talked about a button to create a new album in My Library. I can't find that button and the technician couldn't either, but didn't have any further suggestion.
I found out that I can rename the "Transferred from HiMD" album and get a new one the next time I transfer files from my MZ-NH1, but that doesn't help me with the mess I got in "Transferred from HiMD" now.
I don't need help with creating playlists, that is a totally different issue...
I would appreciate any helpful suggestions.
Frank
All you need to do is right-click on an individual track, choose properties and fill in something in the Album field. All tracks with the same name in this field will be grouped together in "My Library".
Also make sure your view is set to "Albums" or "Albums / Playlists" from the drop-down on the left hand side of the screen in My Library view.
Edited by richyhu
This will work within SS, but, how can I move fisically the tracks to another folder? I normally have my music on separate folders, one for Artist and subforders for every album. And I would like to move the tracks uploaded from the HiMD to other folders to maintain this structure. Can I do this in SS or I have to do it manually with Windows Explorer and then relocate files in SS?
Thanks in advance.
