NH900 cannot play
tasdisr
I recorded a disc on my RH10,but it will not play in my NH900. I get a message in the display
that says "cannot play" for every song. It displays the song title but will not play it. In the upper
left corner of the display it also says"VA", which I have never seen before. It seems to play all
other discs fine. Any ideas?
Edited by tasdisr
  tommypeters said:
What format did you use? RH10 can play mp3, NH900 not. I don't know if there's any of the Sony formats where the players differ, but maybe.
I think you just solved my problem. They are mp3's that I did not covert to Atrac.
Thank you!!!!!
