akijikan Posted December 9, 2005 Report Share Posted December 9, 2005 Can anyone describe how well it works with the RH10? Seems like there's a lot more to it than the other remotes. Does the search button bring up the initial search mode or anything like that? How does the end with DSPL/MENU, SOUND, etc work? What about the group skip on the other end? Thanks in advance for any answers.I have the RM-MC40ELK, but I'm getting the "buy-the-latest-sexiest" itch...if you have used both with the MZ-RH10, tell me which you like more. Quote Link to comment Share on other sites More sharing options...
Richard Posted December 10, 2005 Report Share Posted December 10, 2005 akijikan said: Can anyone describe how well it works with the RH10? Seems like there's a lot more to it than the other remotes. Does the search button bring up the initial search mode or anything like that? How does the end with DSPL/MENU, SOUND, etc work? What about the group skip on the other end? Thanks in advance for any answers.I have the RM-MC40ELK, but I'm getting the "buy-the-latest-sexiest" itch...if you have used both with the MZ-RH10, tell me which you like more. I'll assume you've seen Ishii's pictorial as I think you had a reply in that thread. He is probably the best person to speak to with specific questions on this remote. Try dropping him a PM. Quote Link to comment Share on other sites More sharing options...
