Folders and playlist...
Gonzaloif
Hi everybody.. i wonder if someone can hep me with the annoying soincstage use... i´m from Chile and haven´t been able to find any friends that uses MD`s to help me out with "daily stuff".
I own a RH-910...
One of my biggest troubles (i don`t know if its me or is it just the software...) is the way Sonicstage library organizes the albums i import, wich i usually keep as folders with the name of the album... it is just a huge mess! it seems sonicstage can`t just import the folder and keep it in the library as one unit or "folder", instead, it usually will group the songs in some other folders it creates...
Any solution to this?
Thanks for any hint on solving this... it really make me hate the procss of transfering music to mi Hi MD, so if theres anything that can help... THANKS!
I guess you're referring to compilation albums... as far as I know, the only thing you can do is to ckeck the 'properties' (right-click on the trackname and select the bottom option in the pop-up menu) of each track and manually insert the correct album name and mark it as a rack in a compilation album (checkbox) this will move the track to the correct folder (but it is way too much effort and Sony really should have done this better)
