WaywardTraveller Posted January 11, 2006 Report Share Posted January 11, 2006 Hello,Happy New Year to all of you Unfortunately, I'm now having a problem wtih SS3.3. The last project I did was to rip a 15-volume music set on to MD at 352kbps. Since I'm on Win98SE (yeah, yeah...no use in updating when you're on the road!) there were a few crashes, but more or less everything went off without major hitches.Now, though, when I try to import MP3s and convert/transfer them at once, I don't get a nice polite error; I get an illegal-operation shutdown window with: "OMGJBOX caused an invalid page fault in module ASMAUDDECFF.DLL at 01e7:0f938bc7" (I can provide all the information if anyone wants).So what did I do? I uninstalled and re-installed SS3.3, deleting the OpenMG modules through Add/Remove Programs. What now? Re-installed over the web...same error.If I convert my MP3s to .WAV files and then convert+transfer the WAVs, everything seems to work fine; it's just that I can't seem to deal with converting MP3s (although I can still PLAY them in SS3.3!). I am sure I was able to convert MP3s on-the-fly before, but am unsure what I did to render this unstable.In the hopes that someone can/wants to help me with this, I am giving as much info. as I can below: OS: Win98 SE, Athlon 900mhz, 512MB RAM, USB 1.1; outdated version of Norton Anti-Virus is ALWAYS disabled when running SS (did I mention I've been gone from home for 2+years? )I've used SS3.3 interchangeably with my RH-10 as well as an NH900 and NH800 without previous difficulties. Hell, I even plugged in my Sharp IM-MT880 NetMD, which only made it look for and install a new driver, but this was before the NH900 and NH800 and had no apparent difficulties. Right now I only hook up Hi-MD units.If anyone can shed light on this so that I don't have to batch-convert my MP3s using CoolEdit, I would greatly appreciate it!peaceWaywardTraveller Quote Link to comment Share on other sites More sharing options...
WaywardTraveller Posted January 11, 2006 Author Report Share Posted January 11, 2006 Err, umm, never mind. I Googled my error and found that the DLL in question belongs to the Xing MP3 Encoder/Decoder. I uninstalled it (making sure the DLL was deleted) and everything seems to work fine! Object lesson: sometimes Googling your problem can lead to the quickest solution! peaceWaywardTraveller Quote Link to comment Share on other sites More sharing options...
Syrius Posted January 11, 2006 Report Share Posted January 11, 2006 AND: Xing is C-R-A-P. Quote Link to comment Share on other sites More sharing options...
atrain Posted January 11, 2006 Report Share Posted January 11, 2006 ....Object lesson: sometimes Googling your problem can lead to the quickest solution! peaceWaywardTravellerAND: Xing is C-R-A-P.both true, fact one should be tattoed on people's faces, when people ask you a question you could point to the forehead - i'd get it on mine but i'm pretty hot. Quote Link to comment Share on other sites More sharing options...
