newby with rh910 setting questions
RockyJ
I want to record live session and yet stop and restart without going through settings again.
I just noticed that if I set the rec level to manual it resets to auto when I stop the recording and restart.
Am I doing something wrong or is that the only way to operate it?
Edited by RockyDisc
hi and welcome to MDCF...sorry to say: "that is the only way to operate it"
congratulations! you have just discovered the most frequent complaint about the HiMD hardware! :P
be sure to check out these forums, lots more info in here
even though 'manual' itself isn't remembered, the manual level is remembered if set above 13/30 (if it was set lower than 13 it will revert to 13 next time you enter the menu)... this is just another strange Sony thing
if it is this easy to answer I will ignore the fact that this stuff is ask-n-answered before :P
but: it still is wise to read the 'live rec faqs' and 'pinned threads' as they contain a lot of info
