using omnis as spaced pair
bigjimvt
search for posts/threads by greenmachine... he once posted a whole bunch of test-files with different mic setups
for 'as you heard it stereo separation' a very good setup is with your own head between the mics and to place them as close to your ears as possible... still this requires you to sit/stand perfectly still and to prevent yourself from uttering any sound (I have a great live rec with me coughing through a nice silent part...pretty scary as I noticed it when listening back through headphones while walking through a dark neighbourhood and I honestly thought I was being followed :blink::lol: )
just got a mz-rh910 and SP BMC-12 mics been pretty happy with the results but wondering what is the optimum distance to separate the mics if doing non-stealth recording, (spaced pair mic technique)
Generally, the spaced-pair method uses a recommended distance of 17cm, about the same distance as that between a human's ears.
anybody ever use the jecklin disk?
Cangt say I've used an actual jecklin disc, but I have made similar things myself out of various materials at hand and one does make a difference when using spaced omnis.
[The last one I made was a bad-burned DVD-R with felt stretched over it, and an alligator clip screwed to one edge so it could be attached to things. The rest of the "mic mount" consisted of a large lump of plastiscene, two backplane brackets from a PC, and a couple more alligator clips with rubber boots on them that my mics could be attached to simply by inserting their plastic hook-mounts [sP-TFB-2s] into the boots. It actually worked quite well for something that was improvised in under 5 minutes.]
I'm a believer in baffled recording with omnis. If the distance between the mics equals the distance of your ears and the baffle equals the shape/consistence of your head, you'll get most realistic results ('as heard') when listening with headphones. I don't think it's worse than the other techniques even for loudspeaker playback, which usually benefits from lesser distance to the sound source. I usually direct the mics forward or just slightly outwards for a better front <-> back recognition. I don't like the coloring effect of the pinna, so i don't like to place them in the ears. It would require the use of canalphones for optimum playback. I prefer spheric over flat baffles. For a quick improvisation, i guess a diy jecklin like dex mentioned would also do suffice.
Here's my little test:
http://forums.minidisc.org/index.php?showtopic=11297
I would also prefer spheric over a disc.
This technique [in general] is better for making recordings that are bound for loudspeaker playback.
The "true" binaural method [with 180 degree angular difference between mics] sounds good with headphones but can produce weird results over speakers. Forward-facing elements also produce fewer directional artifacts when put through matrix decoding [a la Dolby Surround]. Binaural [180-degree] recordings when decoded this way send anything that is close to the mics and directly to the side straight to the back channel; the jecklin disc or spherical baffle helps with this somewhat but not completely.
I would like to try a setup like Aaron Ximm of quietamerican.org uses someday.
I'd also like to try 3-channel recording with dual cardioids and a figure-of-8 element, for quadraphonic decoding.
Ultimately, I'd like to experiment with Ambisonics.
In the meantime, I'm still impressed by the results that can be achieved with my SP-TFB-2s or other stereo omni setups.
