OpenMG module numbers
Sony_Fan
I just noticed that the OpenMG module numbers in Simple Burner are the same as those in SS 3.3. Does that mean that they both will burn to Hi-MD with the same sound quality (assuming using same formats and bitrates)? I don't want to store music to my hardrive, I just want to burn to my MZRH10.
  Matt J said:
Hi, from what I gather they will record in the same sound quality as they use the same codecs. But simpleburner does not have a "high" encode quality when ripping a cd unlike sonicstage.
Matt
Does that "high" setting prevent "ripping errors" or does it affect the sound quality? Personally, I've recorded the same song with Simple Burner (Hi-SP), SS 3.3 (Hi-SP set to "normal") and SS 3.3 (Hi-SP set to "high"). Listening to the songs blindly, i can't tell them apart. Can anyone?
