SonicStage 3.4 Region Differences
Berke
Hi,
I just bought a M100 unit, and I want to install the latest SS for the leastest headaches.
I'm using a US M100 but I'm in Europe.
I'm wondering what important differences there are between the regional versions. I'm pretty sure it's mainly language issues (both US and EU are english though), or maybe the Connect music store in the software.
Any significant matter whether I should download this one or that?
Thanks.
Edited by Berke
Principal differences are as you say in the Connect store access. If you live in Europe and download the US version you won't be able to access the Connect store and vice versa. So if you need access to the Connect online music service be sure to download from Sony Europe. Apart from that, no real differences between versions that I'm aware of.
Thanks,
Well, Since Connect Store is not available in my country, I guess I'll stick with the US version.
Thanks again.
