lesjb Posted February 5, 2006 Report Share Posted February 5, 2006 Hi everyone, I recently purchased the MD home unit (MDS-JE330) and for some reason, when I try to record, the unit just ejects the disc. I'm not sure what the problem could be. Does anyone have this same problem? I got a good deal on the unit, so I figure something must be damaged with it. Any help would be appreciated! Thanks. . . Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted February 6, 2006 Report Share Posted February 6, 2006 I have the JE330 and have not experienced the problem you mention. I usually record from my CD deck and use the remote to put the MD deck and CD player on record standby mode then just press the start button. Everything starts up automatically and I just let it go until finished. Quote Link to comment Share on other sites More sharing options...
ATELETRONICS Posted February 16, 2006 Report Share Posted February 16, 2006 did you check the write protect tab on the disk? Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted February 16, 2006 Report Share Posted February 16, 2006 That does not cause the disc to eject though. Quote Link to comment Share on other sites More sharing options...
ATELETRONICS Posted February 16, 2006 Report Share Posted February 16, 2006 just guessing Quote Link to comment Share on other sites More sharing options...
mdenter Posted February 22, 2006 Report Share Posted February 22, 2006 Hi everyone, I recently purchased the MD home unit (MDS-JE330) and for some reason, when I try to record, the unit just ejects the disc. I'm not sure what the problem could be. Does anyone have this same problem? I got a good deal on the unit, so I figure something must be damaged with it. Any help would be appreciated! Thanks. . . Check to see if there isn't something in the slot for the disk. I had the same trouble because one of the kids dropped a puzzle piece in there and the disk would eject. It worked fine after I removed it. Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted February 22, 2006 Report Share Posted February 22, 2006 I had this happen to me for the first time last night. It turned out to be a damaged MD disc. The metal shutter on a TDK disc was slightly bent on the edge, sort of crushed a bit. I did not notice it at first but it freaked me out when it happened. I put in a new disc and it worked fine. Quote Link to comment Share on other sites More sharing options...
