MZ-NH1 / Alternative Power Supply
TheSoulMaster
At the very least you will need the cradle, and a universal a/c adapter configured to the voltage you will be using, or get a pile of batteries and charge them before you go on hoiliday. Much cheaper for the a/c adapter, doesn't take up that much room
Bob
I have a couple of AA battery packs which each take 4 AA batteries. They can plug into the stand and charge my NH1. If I was at home I'd sell you the spare one but it's not possible now. Have a look around, I got mine from Maplin's (UK). The plug size is standard.
Hi Jonny, any clues as to part numbers from MAPLIN or whatever, I've go to go in there next week to get a charger & batteries for my new headphone amp so could get it while i'm there.
Tks,
TSM
I don't think they do them anymore, you could ask. It's a simple black plastic box for 4 AAs that has a short cable and a selection of 6 different plugs to put on the end to suit.
A quick search doesn't find them. You could always get one of these and the other bits and pieces and build one youself.
http://www.maplin.co.uk/module.aspx?TabID=...No=267&doy=24m2
