whatsleftofj Posted March 9, 2006 Report Share Posted March 9, 2006 i think i once read a thread like this, but i don't know where it is or what the solution was...anyways, i deleted things this morning on a 1gb disc (does anyone else ever get a 'ghost copy' of a folder they delete, and then you have to re-delete that one?), and then i added a few folders when i was done. seems all good, but then when i went to play it, the disc says "cannot record or play" or something like that. and when i look at it in SS, the folder images show up but with NO titles for any of the names. also, i can't delete them, and if i click to see the files in the folder, they all come out blank, too.the little switch at the bottom of the disc is okay for recording still.... i don't know what to do! Quote Link to comment Share on other sites More sharing options...
greenmachine Posted March 9, 2006 Report Share Posted March 9, 2006 Sounds like the system file's messed up. Try formatting the disc. Quote Link to comment Share on other sites More sharing options...
whatsleftofj Posted March 9, 2006 Author Report Share Posted March 9, 2006 explain how!? Quote Link to comment Share on other sites More sharing options...
greenmachine Posted March 9, 2006 Report Share Posted March 9, 2006 Sorry, i should have done it in the first place.I don't know what model you use, but on my NH700 you have to press the "navi/menu" button for approx. 2 seconds, choose "edit" -> "format". This will erase all information on the disc and you have to refill it from scratch. There's also an "initialize" function somewhere in Sonicstage, which works basically the same way. Quote Link to comment Share on other sites More sharing options...
whatsleftofj Posted March 10, 2006 Author Report Share Posted March 10, 2006 well i tried to initialize, and i got the error:error code: 0000662e Quote Link to comment Share on other sites More sharing options...
greenmachine Posted March 10, 2006 Report Share Posted March 10, 2006 What about formatting via the unit? Does it work? What about other discs? Quote Link to comment Share on other sites More sharing options...
twine Posted March 10, 2006 Report Share Posted March 10, 2006 (edited) Try to initialize your Hi-MD in SonicStage.Go to transfers and open the Hi-MD, afterwards you can initialize by clicking first on *information about device/medium" down to the right and then you will see it. Edited March 10, 2006 by twine Quote Link to comment Share on other sites More sharing options...
whatsleftofj Posted March 11, 2006 Author Report Share Posted March 11, 2006 the sonicstage didn't work, but once i initialized it on the unit it was a-okay. thanks guys! Quote Link to comment Share on other sites More sharing options...
