3.4 problem
dazzjazz
Hi,
I am trying to upload a recording I made on my RH1.
I'm familiar with the process, having done it successfully many times.
However, today Sonic Stage refuses to recognise my disc. SS trys to read the TOC and just crashes after getting to 99%.
Despite this, Simple burner can read the TOC and I can delete files etc.
I've reinstalled SS, still no dice. The disc seems fine and plays back all tracks etc.
What should I do?
Darren
your RH1 doesn't come out till May/June so I guess there's a mixup in model numbers here
further, as you can play the disc...first recorde it with Audacity (see downloads section) or something alike...that way at least can't lose the content of the disc
Do make the backup as Volta suggests, but also try "hard resetting" the unit:
* remove the disc
* remove all sources of power including the battery
* wait 10 seconds
* re-apply power, re-insert disc, see if it makes any difference
You might also try plugging your recorder into a different USB port on your computer just to see if that changes anything.
It's all voodoo.
