recording md to md
this is my first post so please bear with me,i own sony je440 and sony je480
what i would like to know is it possible for me to record player to player as i have programmes scattered over many discs and wish to put them in some chronological order could somebody please advise me how to go about this if possible...yours hopefully :wacko:
you would HAVE to have an optical out in one deck/player AND an optical-in on the other deck/recorder;; AND, IF you did NOT record the original songs FROM a CD optically. (edit) OR, lift them off a cable or satillite station sotically).!
it you did record the original songs/audio OPTICALLY; then it WON'T let you transfer "optically"; you will have to transfer "analogue" (red & white line-in and outs).
if they are mixed; take my advice and just do it analogue; or else it will either drive you crazy with various volume levels; OR, just a pain to do it.
and i hope these are not in L2.3.4.5.6.7.8.9.10.& 13) j/k
Edited by rayzray
the material i want to transfer is mostly taped off dab radio so it looks like
using the red/white analogue so do i just plug IN on one deck and OUT on the other deck thanks for help/patience
You attach one end of your cables to the line out (or output) of your PLAY deckn and your other end of the patch cord to the line in ( Or input) of your record deck, press play on the play deck, and record on your record deck, and you're in business. Try a couple of sample recordings first to get the feel, soon you'll be a pro.
Goog luck,
Bob
you wanna get used to always keep the volume level at the same place; i try to keep EVERYTHING between 4 and 2 -Db's; keep out of the "red"; althogh red is more dangerous in digital recording..
i like the "head room" and crank up the amps.
i like to catch songs off digial cable and IMMEDIATELY transfer to "Analogue" right away;; analogue is "Fun" and colorous;; digital is boring and greyish.
are you recording music or voice, perfumedgarden?
mainly voice [radio comedy progs]tried it this morning seems ok what ive transfered....thanks to all for patience etc...
Goog luck,
Bob
had a dummy run this morning everything seems ok many thanks for the help,you're all stars
