dougkauffman Posted May 4, 2006 Report Share Posted May 4, 2006 I like to backup my Connect purchase with a hardcopy cd. Since upgrading to 3.4 I can't burn an audio cd. It gets stuck at approximately 40 percent on transfer. Customer Support tells me they're having this issue alot and working on it. Any suggestions on how to fix it? My burner works on other software, and I have tried different brands. Need a cd for the car. Thanks Quote Link to comment Share on other sites More sharing options...
Syrius Posted May 4, 2006 Report Share Posted May 4, 2006 If the track plays, use Hi-MD Renderer to convert it to WAV. Then burn that Wav. Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted May 5, 2006 Report Share Posted May 5, 2006 I like to backup my Connect purchase with a hardcopy cd. Since upgrading to 3.4 I can't burn an audio cd. It gets stuck at approximately 40 percent on transfer. Customer Support tells me they're having this issue alot and working on it. Any suggestions on how to fix it? My burner works on other software, and I have tried different brands. Need a cd for the car. ThanksI've got the same issue with SS 3.4, it just stalls during CD burning. Luckily, I have other CD burning software that works just fine. I hope they come out with a patch for SS 3.4. Not to mention, a new version of Simple Burner. Quote Link to comment Share on other sites More sharing options...
dougkauffman Posted May 6, 2006 Author Report Share Posted May 6, 2006 Thanks for the HiMD Renderer suggestion..Made my hard copy. Quote Link to comment Share on other sites More sharing options...
