lox Posted June 6, 2006 Report Share Posted June 6, 2006 Hi all,I have uploaded my recordings into the SonicStage library. I am trying to create Audio CD but the file is too large for a CD. How do I Create Multiple CDs using SonicStage? Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 6, 2006 Report Share Posted June 6, 2006 Is this just 1 track or multipule tracks? Quote Link to comment Share on other sites More sharing options...
lox Posted June 7, 2006 Author Report Share Posted June 7, 2006 danielbb90 said: Is this just 1 track or multipule tracks?It is just one track. Quote Link to comment Share on other sites More sharing options...
Stuge Posted June 7, 2006 Report Share Posted June 7, 2006 Using Program like Power Zip you can split one file into two or more files & then you can easily burn them on Cd . Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 7, 2006 Report Share Posted June 7, 2006 (edited) stuge said: Using Program like Power Zip you can split one file into two or more files & then you can easily burn them on Cd .Thats useless for an audio cd!!!http://audacity.sourceforge.net/ Use that program and split the track into sections about 70 minuets each!Then you can burn them to an audio CDIf there in the atrac format use http://forums.minidisc.org/index.php?s=&sh...indpost&p=87843 convert the file to WAV before editing...Hope that helps! Edited June 7, 2006 by danielbb90 Quote Link to comment Share on other sites More sharing options...
Herri Posted June 7, 2006 Report Share Posted June 7, 2006 If you imported into SonicStage, you can split the track by selecting it and go to the menu and select Edit > Divide Track. The rest is cake. After you have everything divided, you can burn it onto several CD's in a snap! Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 7, 2006 Report Share Posted June 7, 2006 Remember to backup your track before dooing anything! Quote Link to comment Share on other sites More sharing options...
