Install problem sonicstage 3.4
el0gic
I downloaded the full ss3.4 from this website. On installing, I got some error messages:
from Execute: "c:\windows\temp\ss34\instmsia\msiinst.exe",
the error message - "The specified service already exists"
from WMP: 9.0.0.2980, 1,
the error message - "Please update Windows Media Player to version 7.1 or newer"
In the details, the last two lines read:
Execshell: open "http://www.microsoft.com/windows/windowsmedia/download"
Detected 9.0.0.2980, Windows Media Player 7.1 or newer requiered
(sic)
Then setup stops. I have windows media player 9, on windows me, and everything works fine. I tried reinstalling media player, restarting the computer, and uninstalling old sonicstage (1.5), but no luck either way (in any order). I installed from the same exe on a computer with xp and it was fine.
The version of WMP you should install depends on the OS you are useing...
http://www.microsoft.com/windows/windowsme...es/default.aspx for Windows Media Player 9 Series (for Windows 98 SE, Windows Millennium Edition, and Windows 2000)
http://www.microsoft.com/windows/windowsme...10/default.aspx For Xp
and http://www.microsoft.com/windows/windowsme...11/default.aspx If you don't mind beta software :)
there is 3 options that I can see...
Try version 7.1 http://www.microsoft.com/windows/windowsme...n7/default.aspx (downgrade)
Or try downloading version 9 install that - there might have been a minor update in it since the last download - and try then...
Or try Sonic Stage CP 4.0 http://forums.minidisc.org/index.php?showtopic=9586
Edited by danielbb90
I uninstalled WMP, and then installed v7.1 - ss34 wouldn't install. I uninstalled again and installed v9 - ss34 still wouldn't install. I can't see why this isn't working. Are there conflicts with windows me? Is there a way to bypass the version identification procedure or trick it?
The target computer isn't connected to the net, so ss4 isn't an option.
Edited by el°gic
