RH-10 Read Error
BuckTrump
Like the title says - I get "read error" with all of my discs. One disc DOES work, but only if I'm lucky. Typically - the unit will spin for a while then give the message. Meanwhile - I can't even delete the files to have a fresh disc. Ideally, I just want it to work and I hope the unit isn't defective.
Any ideas?
  BuckTrump said:
Okay, it has been a few days and I still don't know what the problem is. Might there be something wrong with the lens than can just be "cleaned"? And if so, what is there to clean a MD Unit? Any help/direction would be greatly appreciated...
Some members put isopropyl alcohol on a cotton swab and rub that over the read lens. I didn't have any luck with that method so I used a disc cleaner and fixed my n920.
