unignal Posted July 15, 2006 Report Share Posted July 15, 2006 (edited) Was looking into buying a cheap and convenient IEM, and came across Koss The Plug and Spark Plug. Since they are similarly priced, I was wondering if there a difference between the 2 (in terms of sound).I've done some research and got pretty mixed comments about these plugs. Any inputs?The only other IEM I owned was a Sony EX81, before the wire started to rot. Edited July 15, 2006 by Unignal Quote Link to comment Share on other sites More sharing options...
Fat Tires Posted July 15, 2006 Report Share Posted July 15, 2006 Was looking into buying a cheap and convenient IEM, and came across Koss The Plug and Spark Plug. Since they are similarly priced, I was wondering if there a difference between the 2 (in terms of sound).I've done some research and got pretty mixed comments about these plugs. Any inputs?The only other IEM I owned was a Sony EX81, before the wire started to rot. I've owned the Plug and it was awful. Very bloated bass and veiled mids. The highs were completely overwhelmed. I think that these are terrible phones and not at all worth buying. Quote Link to comment Share on other sites More sharing options...
Sparky191 Posted July 15, 2006 Report Share Posted July 15, 2006 The current popular low end canal phone, on head fi is the Sennheiser CX300 or the Creative EP-630. I haven't tried either so I can't comment. The Koss Plugs doesn't seem to be that well regarded. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted July 15, 2006 Report Share Posted July 15, 2006 panasonic RP-JE50 are ok as well! Quote Link to comment Share on other sites More sharing options...
Sparky191 Posted July 15, 2006 Report Share Posted July 15, 2006 panasonic RP-JE50 are ok as well!I actually do have those. They are ok, but to be honest I prefer my cheap MX500's. I also have the PMX100's but they are a little too bassy for me. I'm going to try Koss KSC-75 next. Quote Link to comment Share on other sites More sharing options...
unignal Posted July 17, 2006 Author Report Share Posted July 17, 2006 (edited) my friend has KSC75. They sound pretty similar to my porta pro... Edited July 17, 2006 by Unignal Quote Link to comment Share on other sites More sharing options...
bobt Posted July 17, 2006 Report Share Posted July 17, 2006 Doesn't it hurt putting spark plugs in your ears?? Are they still hooked up to the car??LOLBob Quote Link to comment Share on other sites More sharing options...
unignal Posted July 23, 2006 Author Report Share Posted July 23, 2006 no idea. anyone with sparkplug, comment?btw I just bought the EP630. I feel its much better than Sony EX81.Also a warning to all those buying Sony InEars, the cables may rot after a few months of usage (mine after 9mnths). Who will want to bring earphones with its wires exposed to the street? Not me. Money down the drain. Quote Link to comment Share on other sites More sharing options...
jaylen Posted July 23, 2006 Report Share Posted July 23, 2006 I don't have any experience with them, but I've read that the newer SparkPlug (white) sounds better than the older Plug (purple, blue). Although it's thought that this is due to the SparkPlug having a different kind of tip foam, allowing for a better fit. Quote Link to comment Share on other sites More sharing options...
